Onyx 11 Cutting Problem
jfiscus
Rap Master
The other day our front Mimaki plotter/Onyx started acting up.
When you send a cut file from the Cut-Server in Onyx11 it sends it to the plotter using the "default" setting for the Tool setting on the plotter.
For example, if I change the pressure up to 140 from the default of 80 and save the setting, and then send the job in cut server it changes the setting used by the plotter. It will still say it is using CT1 or CT2, but if you hit remote to pause printing and then hit tool it will say the default setting... hitting tool again then enter will change the settign and allow you to unpause and finish printing correctly for the rest of that file.
And then comes the 100 other jobs needing someone to babysit and change the settings every time.....
HELP!
