Precision
When discussing with our production assistant, why we always set up bleed in Illustrator, or Corel, rather than using Onyx to do this. It seems that when tiling a wall in onyx 12.2, we go into job editor, make sure the image is to size, then go to tiling setup, enable tiling, enable overlap (whatever the job may require), then enable print as separate jobs, everything tiles perfectly, and the measurements seem great. Once you add image bleed, even when just selecting the edges you need bleed on, it seems to add bleed to all of the tiles, rather than just the outside edges of the wrap itself.
Is there an order, or method that this should be done in, so you can add bleed to the outside of the wrap edges, and still apply a 1" overlap, and still run as separate jobs?
Also, when adding bleed, the "mirror image bleed" tab works correctly, but when using "duplication" as the bleed setting, it seems to pull a white line on either side of the graphic into the print, anyone have any experience with what causes this, and how to fix?
If we could understand this better, it would save a huge amount of time, manipulating artwork to add bleed, prior to printing. I have tried to find an operating manual that thoroughly explains Onyx's controls and settings, but have not been successful in doing so. I appreciate any help or advice, life experiences that any of you have with this in Onyx 12.2. We use Onyx 12.2 with our Latex 360, and usually design is either Corel, or Illustrator.
I appreciate all your comments and help.
Have a wonderful day, and a Happy and Safe 4th of July!
Thank you,
Thank you,
