Need Help Onyx Cut server and cutting order
altereddezignz
Has anyone been able to find a way to isolate or change the cut order in Onyx 12 cut server?
I ma using 30" wide reflective material and trying to keep it from rubbing and scuffing itself moving so much.
Hope this makes since.
Cutting reflective vinyl and it has 4 lines of words that total about 125 inches long and 27 inches wide..
It cuts one full length cut of 125 inches full work path by path?
So it moved back and forth the full 125 niches 4 times?
When i used Flexi i had the option to make it cut efficiently. It would cut across the 30" way letter by letter to keep it from spooling back and forth the full 125 inches.
