Onyx Help
Maxphobia
Hello everyone, I'm working with onyx 21.0.1.248 it is failing to rip EPS files. Which wouldn't be a problem if some of it didn't have cutlines on it.
What it would do when I tried to rip, the little pdf rip file would pop up, go away and pop again and then the file would move to failed and it'd give the message "an issue occurred while trying to process "file name".
Here is what I've tried.
• Created outlines on all the text and tried again and failed.
• Made a whole new file and it still wouldn't rip.
• Restarted Onyx rip station, no luck.
• Made a whole new file from scratch and still failed.
• Restarted computer, to no effect.
What worked.
• Saved file as a PDF.
Issue, as everything else had to be ripped as a tiff I'm worried their will be a slight shift in color. Will update once its all printed and let you all know how it turned out. Until then any ideas or solutions would be welcome.
