Outlines with Fpro 7.6- any workarounds?
Gene@mpls
Sometimes when saving a .eps or bitmap the outline will change colors or
not show at all unless the outline is separated from the object (or text)-
do you guys just separate everthing before saving or is there a workaround?
Thanks Gene
Fred Weiss
Once I'm satisfied with an outline, or any other effect, I always execute a "Convert to Outlines" command (Control + Shift + O). This makes it easy to work with but removes the ability to come back to it later to edit it in Design Central.
Gene@mpls
That is interesting- it also changes the text to outlines however. How did
you stumble upon that- it doesn't seem like an 'official' hotkey? thanks Gene
