Pan faces
speedmedia
You just need flat blanks cut to that size?
I am showing $193.00 ea. from Wensco.
That does seem way high.
Thanks,
Kurt
Doyle
when you say pan faces, I would assume that you are not talking about just a flat piece of polycarb, right? Because panned faces this size would also run about $450 from wensco. Flat polycarb would be half that price, depending on the thickness.
agree with Doyle my vendors for a pan face are around the same price some of them higher (for a pan face) but your post confuses me and i am thinking you just need a flat face...
I don't know what a 'flat pan face' really means.
Not gonna talk numbers out here, but if you've been quoted $450 for a 5' x 10' pan face... take it... that's frickin' cheap.
Flat faces... you're getting screwed.
CES020
Gino, I think he's talking blank pan faces, not completed. I agree, $450 would be a bargain for a finished one.
I could be wrong, as he wasn't clear, but it's the only way I could read it that would work with the $450 price being outrageously high as he thought.
Craig Sjoquist
Pan faces are great for good & stronger... quality looking... back lighted advertisement
A pan face is much better looking then flat face or flex face which would be both options
Lexan or type of is better for this
Craig Sjoquist
As far as being back lighted, being the pan face is raised (embossed) about 2" softens the bright spots and evens the light out better
But now with LEDs in the market a even lighting will be easier even with flat or embossed extremes
Poconopete
That doesn't sound like a bad price to me.
Mosh
Shipping cost, don't forget that. Big pans will most likely have a crate charge as well as the motor freight cost. The last pans I got had $100 crating charge they where 5x12.
$450 sounds good if that includes shipping and crating.
