I'm working with Wasatch 6.6 and an Roland CMYK soljet printer.
After printing a few testfile's of an Pantone solid coated guide, i was wondering if i'm using a spot color replacement table in LAB the colors get more accurate.
When i export the original CorelDraw file to PDF with an spot to process setting in RGB the blue and purlpe colors are better as i'm export it to an PDF with spot to process in CMYK. But in CMYK the yellow's are better.
Beside that, in both cases the process yellow keeps a little dirty.
After printing the file in PDF X3 or EPS and replace the color to an LAB value the yellow is much brighter.
What i'm looking for is an XLS or txt file (like the Avery spot color file) wich contains the PMS C name with an LAB value.
This seems to be a good startfile to tweak it myself.
So when Wasatch recognised in PMS named color it replaced it with the right value and it doesn't matter from wich program the file created.
Regards Leon
Regards Leon
