paper sensor help
dannie732
I just purchased used a mutoh falcon (actually an agfa sherpa 50) that has not been running. it will not load paper. I set paper & clamps move then it doesn't go to the next menu. I can't even see if it prints or what else might be wrong at this point.
I was wondering if anyone knew what may be wrong or what I could check.
thanks very much
schurms
I would say................ On mine.........take paper out put lever down and
It should promt you to next menu. Shut off machine with out paper start it up and let it tell you what to do. Thats all I can tell you.
