Perf cut aka die cut on TrueVIS VG2
Impact Color
Does anyone have any experience on perf cutting aka die cutting on the TrueVIS VG2 you can share? I’m wondering if it can cut through a vinyl backing and if it would be pretty effective.
victor bogdanov
I perf cut on my vs300, works good as long as you don't forget to replace blades and get the settings dialed in for the material.
Vg2 should work the same as its the same cutting setup for the most part.
If you have lots of stuff to cut a separate cutter is the way to go as perf cut is relatively slow
