Hi,
We've developed a problem on our vj1614 where the left side of the platen heater will heat up and not turn off. Eventually the machine will throw up a 077 error which I think is due to the machine overheating. It gets so hot that you can't touch it!
The strange thing is the machine doesn't need to be turned on for the heater to start, only plugged in which I'm guessing is now a fairly major fire risk. Lucky we were around when it started.
I've taken off the platen heater and disconnected the thermistor, plugged the machine back in and again it continues to heat up.
Has anyone any idea what the issue could be?
Colin
Colin
