Stephen Paul
Hi All,
I work for a traffic control company and make road work signs, so I only use my plotters for cutting. I currently am using FlexiSIGN 12 build 2324 and a Graphtec FC7000-160. However it is really old and doesn't cut all the way through on one spot anymore and have tried everything to fix it.
The reason for this post is because I also have a Mimaki CG-160FX that works fine and we use it to plot with fine cut from Adobe Illustrator. The only problem is my FlexiSIGN files are not compatible with illustrator so I can't use that to plot my thousands of file signs I cant even tried copy pasting from flexi to illustrator but also incompatible.
I have latest Mimaki CG-160FX Driver and Added the device to Production Manager in FlexiSIGN, set it to active, I press REMOTE on the mimaki and also set port to USB001 but it did not work. I don't know what I'm missing. I'm under the assumption that these should work together because the Mimaki plotter was among the list of plotters in Flexi's production manager when I added a device.
I'm sure it's something simple in the set up or communication. Any help or information would be greatly appreciated THANKS!
