Hi. I'm new to this forum and wished I had discovered you all years ago.
I just had a repair tech replace my Epson 7890 main board. I thought all was fine but when I tried to switch the black ink the printer went into an endless loop and never completed the task. I had to force the printer off by unplugging it. When I called the repairman he suggested that the Print Head might be shorting the printer out.
Can the firmware be the problem, not the Print Head? It seems odd that doing a nozzle check would work but changing ink from glossy to matte would not.
The repairman also updated the Firmware. On a Mac the only way to check the firmware is using the Remote Utility. And when I was updating the OSX drivers I ran the check and the utility errored out with the message "Failed to acquire printer information. Check the printer connection".
If that's the case does anyone know of steps I can take to re-install or confirm the firmware is not the problem?
