I milled one side of a MDF mat and all was good.
Reversed to mill the other side and stuck it down.
First mill went fine, started mill job and the router moved to the top-right and error.
So restarted the machine. Moved to origin fine.
Moved head to set bit height, and initialised.
Sent the router home. All's good.
Sent mat mill g-code as before and once again the router moved to top-right. I hit reset to prevent it getting stuck and then the need to rewind the x-axis.
I've tried undo home and a few other things but the error re-occurs as soon when I hit start after using last depth etc.
Closed ArtPath and resent file but no change.
I presume I'm doing something silly. Can any assist?
