Print Scuffs on the 365
JamesLam
So I started a run today on the 365 and I had a few scuffs which were literally right in the middle of the print and seemed to follow the same spot as the roll unfurled. After some clean up and other maintenance that was over due I set up the job again and the problem seems to have gone away.
Could it be a factor that recent swings in humidity affected the outer few layers of the paper media or am I missing something?
JamesLam
It could, could be anything. You can raise your vacuum a little if you are afraid of future issues.
I did have one rather aggressive scuff again this morning on the first output. The increased vacuum seems to be today's solution. Thanks, all in the world seems to good again.
