printing small .eps
signguy35
So i was asked to make a little 1.5x2 decal to put on rain guages for our local Pheasants Forever. i designed and printed it to size. wow it looked like junk. So i designed it larger and then downsized it in versa works. it looked ok but shouldnt a .eps look crisp when printing?
SightLine
What does the eps file type have to do with anything? EPS - encapsulated post script. You can embed just about any sort of image in an eps file container - thats not going to make it any better or worse for the most part.
You arte using versaworks so its a given you have a roland of some sort. Dpending on what is creating the file and the capabilites of your roland dictate the file type you want. Thats a small decal regardless though - not all large format printers can do text under 10 point very well - some can print 3 point text fine. Just not enough information from you on the design, machine, and what you are creating the design in.
signguy35
its all vector. printing on Cal Arlon digital print media. and my color wasnt really solid. maybe i didnt have the heat up enough. im still new to this digital printing so please bear with me.
J
john1
Guest
vectors ALWAYS print crisp for me, Hell i even printed a high res JPG a client had for artwork and it had 1/16" text on it that printed well also. I print on high speed mode and the basic vinyl profile with great results.
I say it's your heater settings, I have my heaters all the way up on my Roland (112 degrees), i find this prints less grainy and if you print on matte adhesive vinyl like i do, those two tips reduce all print grain pretty much. You can then overlaminate the matte vinyl with gloss and it looks GREAT
J
john1
Guest
actually, try printing these on high quality mode. I do remember that on a smaller job the high quality mode printed more crisp beings it was such a small print.
jfiscus
Rap Master
You're gonna need high quality mode on a Roland for something that small, and as mentioned before high heat.
For small pieces we print using our EdgeFX, it's great for small stuff; we just printed some 1.5cm x 2cm decals for a customer a couple weeks ago.
