Problem with jv-33 post heater
IDEOGRAMMA
I have a JV-33 160 3 years now and yesterday i saw on the display in that under the POST HEATER indicates "BREAK". Of course the post heater doesn't work. Do you knpw something about it?
:help
MikeD
Not sure what inks you're using, or the cause of the error is, but since the front heater is supposed to help dry the prints, you should still be able to produce. Not sure if you're on a deadline either, but your prints should be dry after 24hrs. fans and heat will expedite drying
Good Luck!
