Problem with my vj1204
trebor28
Hello, I dont know why it happens but my printer has decided to play up during my busiesest period.
Hope some one can help - I noticed bad banding on anything i printed, so i did my normal clean of the maint station and printhead and did a couple of little charges as well. But nothing helped - on futher investigation I noticed that one of the two magenta ink lines seems to have a bubble in it - is there someway i can suck the air out? or possiable clean the damper?
The nozzle check shows all other colour 100% and about 50% on the magenta.
Stealth Ryder
There is your issue, you must have 100% ink flow for the machine to work properly. Use a syrings and pull a manual draw from under the Maintenance Assembly. Is the Cap Top Clean? Is the Print Head Capping properly?
