sierragirl78
Printer, Cutter, Web Designer, Graphic Designer
We just brought 2 XR-640 Rolands and both seem to have the same issues. We also have an LEJ-640 and an LEC-540.
We print on nothing but 7mil Permanent Stick clear vinyl and 7mil Static Cling Poly. Both are clear. Both run white on every job.
For what we are doing, the media clamps and takeup are useless. The longest we ever need to run is about 200".
Issue#1: Ink drying time.
Unlike with the LEC and LEJ, the white ink has to dry overnight. We cannot print and ship the same day. The heat does not set the white fast enough.
Issue #2: Print speed.
Unlike with the LEC and LEJ, the white ink cannot print on highspeed. The best we can seem to get is in the CSC profile, printing color and white at the same time, and increasing the head speed to its max setting, which cuts on quality and opacity of white considerably.
Issue #3: 2 pass misalignment
Unlike with the LEC and LEJ, if we run color on its highest speed and then automatically back up, and print white on top (or vice versa), the 2 layers are misaligned AR/y direction. The longer it goes, the further the misalignment, even with all tension taken out of the roll or if it is rerolled after backup.
Issue #4: Roll to Roll Reversal
Just like with the LEC and LEJ, the XR has a great roll to roll takeup system that completely fails to register to automatically reverse when the rollers reverse. You would think they would connect the two systems.
So, if anyone has any tips or tricks that may help us in our quest for truly faster printing with the XR-640, we would love to hear them.
(It seems like there should be a way to print white on highspeed, just like with the LEC and LEJ, which happily prints a semi decent opacity of white on high speed).
Thank you so much,
Sierra ♥
Thank you so much,
Sierra ♥
