Seth Griffin
I'm getting some odd readings on my calibrations - the generated curves aren't smooth. When I try to import the profile to another identical printer and then calibrate for that printer, it says that my readings are out of range, and can't be clipped. (In other words, I'm going to have to rebuild the profile for the other Roland printer we have.)
I'm using Onyx Thrive, an ancient and uncalibrated X-rite Eye-One spectrophotometer (rev. D), and Roland Pro II SJ-1045EX printers converted to dye sublimation. I'm printing on Beaver TexPrint paper that's (I think) 140gsm, and transferring to Fischer tri-poly fabric through a rotary heat press. (I'm not sure what the time under heat is off the top of my head; I think that it trips out the heat strips at 206C.)
I'm setting my initial gamut for extended or coated (both appear to be the same), because uncoated gave me washed-out colors and shadows. I've got it set for FDRP enhanced at the moment (rather than stochastic). The initial ink restrictions seem to go okay, more or less, as did ink limits. I set my ink limits a little higher than I might normally (i.e., seeing a very small amount of artifacts from pooling ink, but it's still drying okay) to allow for more saturated colors. Once I do the calibration, it all goes sideways. As you can see from the attached screenshots, my curves look more like steps, with small spikes all over the place. For instance, patch A1 has a density of 1.510, but then A5 has a density of 1.509, and so on. It doesn't matter whether I read in strips, or individual patches; I get results that still show spikes.
Any ideas what's going on?
Link to images:
https://imgur.com/a/fXEVnLn
Link to images:
