Program to reliably round corners?
Gene@mpls
We use Flexi 7.6 to design and the round corner function sucks- one of
the only things I don't like about Flexi- the older version (5.7) this worked
a treat. When we cut graphics/lettering that has been laminated on a
drag knife cutter (GX-500) it wants to lift the sharp corners (not as bad as
cutting on the VP-540 BTW). I would like to be able to open the eps file
that I print/cut from and apply a round corner to all the contour cuts. I
found a script for AI cs2 that works... kinda- but not as well as Flexi 5.7.
I know, I know... I am an old **** wanting to go back to the old days. Gene
J
john1
Guest
Could try CorelDraw, That's what i use and it works great. I believe it's called Scallop/Fillet
