Pump hose getting bunched up in pump
Graphics2u
oI have a fairly new pump on my Falcon II Outdoor and al the sudden I notice the cyan pump isn't working. The hose that runs through it keeps getting pulled through the pump as it's running. Before long it's all bunched up inside the pump. I've taken it apart and re-routed the hose back where it should be but it will do it again in no time.
Anyone had this happen? Need new tubing or what?
Graphics2u
Figured it out! The pump is a solvent pump and the tube is good. There was a small piece of black rubber on the old pump that was wedged into the groove that the tube lays in holding it in place. So I started looking around the printer under the pump area and found the same piece of rubber that had popped out of the new pump. Wedged it back in place and it's fixed!
