Click to Support Signs101 ...
Seems that when the mutoh falcon outdoor 62 sits for a few days the pump lines seem to clog up with ink. Now I do do color pattern prints daily even if I do not print anything with it. Curious if it is just lack of use or another issue.
Thanks, Rod
Is your shop really dry? Mine is in the basement and I run a small humidifier to keep the humidity a little higher. My HP printer ink used to dry up fast. Not anymore since I put in the humidifier. Don't go overboard and put to much humidity in the room though.
The temperature in the shop is set at 55 at night & 68 during the day.
I do not have a humidifier in the shop it may be the dry air.
Does anyone else have this issue.
couple of days? jeez. Mine (oce cs6060) can sit for at least a week no harm no foul just a mild clean and its back to 99% (where it started when I bought it used)
I replaced the capping station about 6 months ago. I was using wincom digital ink and went back to oem maybe the wincom ink affected the lines. I am going to replace the lines and caps and see what happens.
Thanks for the suggestions.
Replace the entire Maintenance Assy, should be done every 18-24 months in my humble opinion to maintain proper inkflow... If any part of the Maintenance Assy begins failing it will cause a domino effect whereas other parts will begin to fail as well...
