Hello, i have a CE5000. If i choose in Cutting Master to use conditions from software, still the cutter uses the conditions set to lcd. Meaning i cannot override cutter's conditions. Any recommendations?
On the cutter front panel > menu set the Condition Priority to Program
Yes it does...the ce5000 manual tells which setting to choose for which Manual or Command priority...
http://www.graphteccorp.com/support/manuals/CE5000/CE5000-UM-153EGG.pdf
Section 5.1 "Descriptions of Special Function A"
4th paragraph down "Setting Priority" - choose COMD (COMMAND) from menu instead of Manual...page 5-2
Actual chart on page 5-4 of manual Section 5.2 Step 1, 3rd block down from top using GP-GL command mode...
If I recall correctly Cuting Master uses GP-GL.
