SignSourceofMobile
I use a Roland VS-540i and I've noticed that if I say, have 100 stickers to print/cut, the plotter won't necessarily cut each sticker in order - for example if I have a row of 10 stickers it'll cut the one on the far right first, then skip ahead to the 4th, then back to the 2nd, then over to the 7th, etc. It seems like this takes up more time than if it cut them out in order so what's going on here? Is there something I can do on my end to ensure that they will cut out in sequence?
Also, when I send more than one job at a time, there are a few inches of blank vinyl left in between each job. Is there a way to reduce this space?
Any suggestions are appreciated! Thanks in advance.
