Remove adhesive from Avery 3001??
Theflex
Hello,
We just removed a vinyl we tested for bus advertising, unfortunately, the adhesive remained on the vehicle decor made of another vinyl that the bus has. On painted surfaces, the adhesive did not remain. Does anyone have a good tip on how to dissolve this adhesive from Avery 3001?
we have tried Isopropanol and some stock adhesive remover...
VizualVoice
I just learned how to change my title status
I'd give mineral spirits a shot. It does a number on most adhesives but won't harm the automotive paint. Will leave a slightly "oily" residue behind so you'll have to follow up with some dawn and hot water or iso alcohol to get rid of that, but should soften and allow the removal of the adhesive if you're lucky.
Mike Paul
Super Active Member
Rapid Remover.
Not cheap but works well.
Stay away from the edges of the previous vinyl you didn’t install…
Take pics to cover yourself.
