Removeable rigid sign
10sacer
Client is looking for 30" discs on 1/8" PVC that can be hung on painted drywall for events and press conferences at different locations and then removed with no adhesive residue left behind and then used again at a later date.
Any suggestions for best way to handle this?
10sacer
Yeah... that was the easy answer, but didn't know if there was an adhesive like you can mount to back of styrene that did the same thing
SD&F
Yes, Scotch makes a double sided tape product that removes easily from wall with a pull and it just sucks right off. I can't remember the name, but it is like a rubbery piece when put on the wall. That's the best description I can give you right now, it is available.
BigfishDM
This would work for that:
AD-Mount REMO Mounting Adhesive - NEW PRODUCTS
Solvent-based acrylic adhesive, clear carrier, great inexpensive options for remo apps
EMR-51180 AD-Mount Perm/REMO Adhesive (51 x 180ft) 255.00
10sacer
How often can it be applied/removed/reapplied before it starts losing adhesion properties? the sign won't weigh that much itself, but you never know what dirt/dust is stuck on someone's walls.
BigfishDM
I have no idea but I will try and find out, there are going to be alot of variables obvioulsy.
