If it was laminated, probably. Start with lightweight removers - paint thinner, turpentine. Maybe one of the citrus based cleaners. Avoid anything with ketones, acetone, lacquer thinner... those will screw the laminate. You might even get away with buffing it off with automotive clear coat grade buffing compound. Follow that up with a regular wax which will help bring the luster of the laminate back as well.
