Replacing Plastic Tools With Aluminum Tools
The Big Squeegee
Long Time Member
We will no longer be producing the plastic Laminator and Cut Vinyl Tools. They are being replaced with the aluminum laminator tools. We will continue to make the Yard Sign and Rivet/Dent Tools.
We now have a plastic cover that fits over the application edge of the aluminum tools that will make masking possible. The plastic cover can be removed and reinstalled as needed. This cover makes the Cut Vinyl Tools obsolete as it will make it possible to mask any width. All new aluminum tools will have the cover included.
We also have a takeup roll kit available. We call it a kit because you will need to supply parts of it from stuff you might be otherwise throwing away. Each kit requires 2 plastic pop bottle tops with an 1/8 hole drilled in the center and a vinyl core the same length of the tool. You can see how it will work at Aluminum tools The video is at the bottom of the page.
  • Agree
Reactions: 1 users
