Gene@mpls
I am setting up my RF-640 (print only- no contour cut). It prints the crop marks about .4" from the right edge of the vinyl- no matter what I do.
Is there a way to force the whole print (with the crop marks) over to the left side? Using 54" vinyl with a GX-500 cutter that needs the crop marks
farther over. IE the 48" cutter will take 54" vinyl if the crop marks are farther from the right edge- overwise have to cut a couple inches from the
left side to position it correctly.
I am moving from a VP540 where you could position the outer grit rollers to compensate. Thanks Gene
