Roland gx24 plotting issues
billmears
i own a roland GX24 camm 1 servo and all of my cuts are coming out in a 'pounce' type cut .....i have tried adjusting the blade depth, the blade pressure, and everything else in the manual....
i can't weed these pounces as the vinyl is cut without a clean line....there's a break in the line every cpl mm's, creating the pounce factor....
what do you suggest?
thanks, bill
OldPaint
new blade? new cutting strip? or are you trying to cut a BITMAP??? you do know what a vector graphic is ???????????
BobM
Sounds like your cutter is receiving the wrong cutting information. You should be cutting at about 80 grams for premium vinyl. Try creating a new 6" circle in a new file and sent it to cut. See what you get.
DRamm76
New blade holder...New Strip..periodically, you should take the blade out of the machine, drop a bit of WD40 in the holder, let it sit for a few and blow it out with an air can.
