Mathew Atkin
Hi We have a Roland LEC540 running CMYK plus Gloss and White however we do not use the gloss so it gets wasted in the waste tank. Does anyone have any info or guides on swapping the printer to CMYK plus White White as we use white a lot.
I have done this process before on a mimaki however there is a lot more info regarding them online over the Roland. I am assuming the Damper and Cap top would be replaced. The thing I am unsure on is how you tell the printer the configuration has changed.
Also would double white increase the speed of white printing?
Thank You
Thank You
