Roland SC540 Capping an CLeaning issues
Buzza87
Hi All,
I am new to the forums and am looking for a little advice/help...
I have a Roland SC540 running Roland Eco-Sol Max inks. In 12 months since it has been serviced i have not emptied the waste tank once and it is still bone dry! :-S It is running the new style roland pump and the latest firmware... i have replaced the caps and tested the pumps and still no luck... i have also spent hours on a limit initialisation making sure the heads are aligned perfectly with the caps and i am still getting nozzles misfiring... Can anyone suggest anything that i can try to fix this... surely it is a common problem?
Thank you in advance! :thankyou:
Buzza
