Click to Support Signs101 ...
Hello, at what minimum temperature can the room I keep and work with Roland xc-540 be allowed, what conditions do I need in the room to be able to keep it, can there be moisture...
Those specifications can be found in the manual or online. Best to follow those as close as possible since atmospheric conditions will greatly affect print quality.
I see no difference in printing at 60 degrees f to 90 degrees f with very low to very high humidity and everything in between. i turn off ac/heater when we're not at the shop so it can be as cold as 40 degrees or as hot as 90 when I start the printers and there is no difference
