I would just do the 6 month maintenance (cap tops, dampers, wipers, scraper). Kits range from $100-150, you can do it yourself if your comfortable or have a tech do it. Preventive maintenance is key.Ok.. Will order one then..
Just realized the date of the last post. sorry for bumping an old thread. Not used to being on the forum on an actual PC lolI would just do the 6 month maintenance (cap tops, dampers, wipers, scraper). Kits range from $100-150, you can do it yourself if your comfortable or have a tech do it. Preventive maintenance is key.
Where do you get kits for a Roland SP540V you mentioned?I would just do the 6 month maintenance (cap tops, dampers, wipers, scraper). Kits range from $100-150, you can do it yourself if your comfortable or have a tech do it. Preventive maintenance is key.
theres a local shop that I use, but I've seen them on eBay at that price.Where do you get kits for a Roland SP540V you mentioned?
