Roland Versacamm SP-300 small letters are blurry PLEASE HELP
I am printing labels for jars. The big type is good, but the smaller type is too blurry to read ? ? ?
THANKS IN ADVANCE & HAVE A GREAT WEEKEND ! ! !
FrankW
How look the nozzle test? Bidirectional printing adjusted? Try to slow down scan speed.
Zoogee World
Domed Promotional Product Supplier
As mentioned above, how is the nozzle test print? Also, do you have photos, which might also shed light on possible problems.
Newei
HEAD ALIGNMENT(Make sure the print head is parallel to the sacn), BIDIRECTION ADJUSTMENT, ADJUST BI-DIR, FEED CALIBRATION,
Please refer to my solution.
LiqueColor
First thing you need to do is clean the encoder strip with alcohol. Then do a printhead alignment. Then go to uni directional. Are you using OEM ink?
