Jim Hill
My Roland Versacamm SP-300 was printing fine until I reformatted my hard drive and now the print quality is not good and it appears that the printer is printing faster then it ever printed before.
I am using ColorRip which has always worked fine up until now and for some reason it won't contour cut.
I have reset the spot color and set it to "CutPath" and still it is not cutting.
After reformatting the hard drive I did down load the latest drivers for the printer and I am wondering if maybe that is part of the problem.
I am using CorelDraw 12 and sending the images in a EPS to the printer.
The printer seems to be printing much faster then it ever printed before and that could be why the quality is not good.
In setup I have the setting set to print high gloss calendered vinyl.
I am open to any ideas you might have about how to correct the problems.
Thanks Jim
Thanks Jim
