Roland Versaworks
Every time I send a job to print it says "job cancelled, printer is disconnected" and the printer says "now processing" but nothing happens
I shut everything down & reboot ... but the same thing happens
blufftonsignguy
I had that happen before also. Once I had to reset my router. The other time, I ended up having to replace my switch box between the computer and the printer. Thats the best information I can give you
GVP
This happens to us periodically. No solution we've found except restart everything and keep the environment temperature up - it seems to happen worse when it's cold. We tried a separate network card in the computer, but it doesn't make much difference. It's a royal pain when it disconnects with 6 inches left to go on a print :banghead:
CraigJ
I had the same problem with the Roland I use to use. I would just restart everything and it would come back up.
AskJessie
-Check to see that your hard drive on computer is not falling asleep. also turn off screen saver.
-remove gateway address from printer
**its possible the main board is going. if your first couple prints stop, but its ok for the rest of the day, id consider a new main board.
If you cant figure it out, give Grant Graphics a call 518.583.2818. They should be able to help you...
phototec
I had that happen ONE time, I don't know what fixed the issue, but I tried several of the things that has been mentioned here. I just powered the printer off, the computer off, checked all the connections, then brought everything back up and it started working. Give it a try...
TXFB.INS
try running the printing directly to the comp instead of a router/hub/switch
this will help with the drop outs
Jester1167
It was a long time ago but I remember that we got this so often that we had to replace the network card on the printer. Make sure you secure the network cable to the printer so it doesn't pull on the connection or it gets damaged.
Ragnabrok
Is it a USB printer like an SP-300, or ethernet?
How many jobs are in the queue? VW has an upper limit in the 200's, wonky stuff can happen.
It will empty the queue, and wipe out pretty much all your custom settings, but in the VW start menu, there is an option "initialize application" that can clear up some weird issues.
thanks, it's a SP300
Ragnabrok
Does the statis in VW ever indicate the printer is ready, and drop do disconnected after, or is it always disconnected?
If so, could be the cable. just unplugging it you should hear windows make a USB disconnect sound. IF it doesnt make a sounds, try different usb ports on the computer from and back. IF one of them works, great. if not, try another cord. if not that, i've seen the solder break on the USB connector on the main board. I can't solder myself out of flux handcuffs, but im sure there are local placecs that could do a patch job cheap, even a tv or audio place as i use locally.
