If you've upgrade to TR2 inks, you have the ability to run the damper fill routine: Power down in front and then press and hold the [Pause] and [Enter] buttons while you power on from the front control panel and follow the prompts. Do this twice. If you have good dampers and have not damaged the print head with a head strike, you should be good to go.
Good Luck
