Roland VG2 end rollers will not engage
grafikguy
President
When the lever is pressed down to engage the rollers, the end rollers slide freely side to side and only the middle rollers work. Does anyone know of an adjustment or easy fix for this problem.
netsol
perhaps a setscrew came loose and the arm is out of "timing" so it moves offset but doesn't find a home position
cornholio
Most of the time, the roller holders are broken and need replacement. The springs of the outer rollers are much stronger and the plastic part, holding there rollers is too weak.
