ROLAND VP-540 Will not power up
Adam Edge
Hi All,
VP-540 not poweing up. checked board fuses are ok. Replaced main board and powers up so problem is with main board. Does anyone know what to check on board? I have the working board so I can compare componant values. Can someone point me in the right direction please. Thank you!
P.S also checked and working battery and 8 head transistors
damonCA21
The fuses and head transistors on the mainboard don't have anything to do with the power. You need to trace the power from the input through the board, test voltages to the chips, check caps, transistors, regulators, look for shorts etc.. To be honest it's not something easy to do if you don't understand circuits.
You can spend hours checking it and not find the fault, you are better off getting someone used to repairing and diagnosing boards to do it for you. It could also be a failed main chip, which isn't repairable as you can't get replacements.
Having a working board can be useful, but you need both boards powered on at the same time to test them against each other
I do do board repairs for the VP, but am in the UK so you would need to send it over here for me to be able to diagnose it for you .
damonCA21
Hi All,
Hi Adam, just replied to your ebay message as well, feel free to message me on here :)
Adam Edge
haha, thanks mate just saw!
I see what you mean. found this guide, might give it a go:
damonCA21
No problem, the caps are something always worth checking anyway. It is unusual for them to fail on a VP board though, I see this only occasionally, but worth giving a go. If you do decide to change them, be very careful desoldering them as it can lift the pads !
Adam Edge
have you ever fixed no power issue? what did you have to replace?
