New Guy Roland Vp540
Michael Barbare
Help
Roland vp540
Always use Roland ink and parts
Magenta and yellow stop printing at same time
I did manual clean
Installed new cap tops all 4
Pulled vacuum on magenta and ink comes through
Pulled vacuum on yellow and it will not pull ink through into the syringe
I am assuming you are trying to pull ink through the hose on the cap...
Double check your new cap top. There is a little white piece of plastic that hangs off the bottom of the cap... be sure that it is towards the back of the printer when it is installed, otherwise the cap will not sit properly in the capping station.
Also, sometimes the cap will sit kind of crooked even though it is installed properly. Take a look at it and make sure it is sitting the same as the others... if not, you can tap it with your finger to get it seated properly.
I have to mention this, as some people do this... don't install the new cap onto the old hose. This can cause the same issue.
Michael Barbare
Michael Barbare
So I have done the suggestions and double checked the cap tops
Is it possible the print head needs to be adjusted
I moved this printer with me about a 2 hour drive down the interstate I did put the print head lock on it and prepare it for transport
But since it have been set up at new location it has been off a little ?
Joe House
If you're getting no ink out of either head, then your problem is the head fuse on the main board is blown. The real question would be "why did the fuse blow?" If you've been plugging/unplugging cables with the printer plugged in, that would do it. Spilled ink on the head or cables could do it. A bad head could do it...
Lots of reasons. Could also have been a transient spike the just took out the fuse. Hard to tell. Check the fuse first.
Michael Barbare
Michael Barbare
A car accident took out a power line and the power to the shop makes sense about the fuse
I know that there are 2 glass fusses on the bored are there any others ?
