Roland VS-540 No ink while printing or Test Print
VinzLHP
Hello !
I got a Roland VS-540 with nearly new Printhead, CapTop, Dampers etc.
Since a little time, the Cyan had totally disappeared and came back a few partially.
Now, all colors have disappeared while printing or on a Test Print.
But when I do a Powerful Cleaning, i can see the ink coming on the printhead...
Has anyone an idea of what's happening ?
Thanks for helping, you're my last hope..
Vinz
Signarama Jockey
New printhead, new cap top, new dampers. Cyan went out and all colors are out.
It sounds like the lines are pinched off. Depending on how much printing you've done since all of the work was done, it could be that the tech never opened the lines up after doing all the work.
I wonder if your choke isn't closed.
...although, that doesn't explain why you'd see ink coming out during a cleaning.
damonCA21
I would bet on a mainboard problem. If ink is coming out on the cleaning, but not on the print, then the heads aren't getting the correct signals to make them fire. Head fuse is most likely, but could also be transistors or the main board has failed or a bad print carriage board. You really need to get technician out to look at it as there are lots of reasons a head doesn't fire.
VinzLHP
The cables are also brand new by the way. Could you please tell me where the fuse are, i'll then try tro test 'em :)
damonCA21
There are two fuses on the mainboard. They are small ones in white holders. If you look for the two large metal heatsinks, go down from them and across to right next to the cable sockets they are there
damonCA21
They are small rectangular ones about 8mm long. White, with metal at each end and are in white plastic holders
damonCA21
