No, but you can run a print cut test and adjust from there. Menu/ Cutting Menu/ Print cut adjust.
Also, if the cut is close but moves around from one sticker to the next, then make sure your cut pad/ strip is new with no grove and your blade is sharp with the minimum amount of pressure to make a clean cut. If the blade is dull it will literally push the vinyl around causing cuts to be off and if there is a groove then the blade will dip into it and cause issues as well.
Hope this helps.
