graphicsphere
Trying to find out which order the colors of the Test Print are in for a Roland VS-540i so I can find out which color is missing nozzles to flush with cleaning solution.
Looking closely at my test print I think the Color Order is Light Black, Cyan, Magenta, Yellow, Black, Light Magenta and Light Cyan. I just need someone to confirm that it is my Light Cyan that is missing nozzles in my test print.
I have attached a picture of my test print and the view of my ink lines going to my dampers.
The cartridge order I have the printer setup with are Light Cyan, Cyan, Light Magenta, Magenta, Yellow, Black, Light Black and Cleaning Solution.
After I find which color is missing the nozzles do you think I should try flushing that ink line with cleaning solution then replace the damper and Cap top? What else should I do? Head soak?
Thanks,
Thanks,
