Router not going to full depth
homa
Hi,
I have a problem with an AXYZ 5012 router, when I run my job the final pass in .020 inch from the bottom of the material. I've tried changing the number of passes and increasing the depth to compensate but it still stops shy of going through.
Anyone have an idea?
Z SIGNS
Could be many things
As a signtist you have to do some Troubleshooting
The same could be said about all equipment and operations in a sign shop
Unlike printers these machines are pretty simple and usually do what there told to do.
When I am cutting all the way through I usually go at least .06 and cut into a sacrificial sheet.
First thing I would look at is the toolpathing.Is it correct?
Is it operator error ?
Forgot to zero properly?
Zeroed from the bottom and should have done top?
Wrong bit for the job?
Is the table not flat?
Is there something wrong with the machine like a loose spindle?
Does the machine ever have a problem cutting within .020 ?
Did you first check all the obvious?
This list could go on and on and on.
Hope this helps and you solve your problem
homa
Tried many things
Hi, thanks for the input,
I tried several things including increasing the depth and the number of passes, re-initializing the z-axis in different places, putting the bit out further from the collet, all to no success.
Are you zeroed from a table or from top of the material.
if table probe your spoil board.
if top of the material measure you material.
Check for a backlash on Z axis.
homa
zeroing
The machine is equipped with a z sensor that automatically sets the zero from the top of the material, we use a digital caliper to measure the thickness and determine how far we'll go into the spoil board. The material is .368 aluminum and I started by setting the depth to .370 which would work perfectly under normal circumstances, when it didn't cut though (the cut was .344 deep) I tried it at .400 but the final pass was at exactly the same depth.
homa
Problem solved
Not sure how but as mysteriously as it came it has now left.
Thanks for all the input.
