Need Help S2 T140 panelling issue
oparusic
hi all.
Im pretty new to this forum but want to check if you guys have any solution for my problem.
When i chose panelling on or 4 marks, my summa reads the first 4 marks and cuts all it should.
but then when its about to re-read the mark number 3 (because it is the new mark number 1 for coming panel) it doesnt find it at all even though the eye/light goes over the mark (and it read it first time for panel 1)
Im trying both through Summa Cutter Control and SignCut Pro 2, same fault.
If i cut without panelling it all works, it read all the marks without problems and cuts all of it.
I have tried to re-install everything, software, firmware, driver etc etc but to no use.
Has anyone of you had the same issue and know what the problem is?
Brani
