sc 540 converted to cmykog has clogged head
luggnut
i am working with an older roland sc540 that has been convert to bulk megaink cmykog... the magenta head is not firing all nozzles.
i have done a head soak on a mutoh falcon before . i soaked a lint free rag in cleaning solution and then placed it over the capping station then pulled the head over and let it sit.
can i do this with this roland or is there a better way to get the nozzles back?
ddarlak
Go Bills!
hook a 6-9" tube to syringe, pull cleaning solution into syringe, connect to head nozzle, place paper towel under head with enought room to observe with a flash light, push solution throught untill you see all the heads open up.
i do this all the time.
luggnut
so you remove the damper and connect there? then push cleaning fluid thru?
ddarlak
Go Bills!
i have pushed as hard as can and havnt damaged a head.
i have been doing this type of head recovery for at least 6 years, you have no worries.
matter of fact, you'll be impressed at how long you can keep a head running.....
ddarlak and tomence,
What size tubing do you use when you connect the syringe to the head nozzle? Ink tube is too small. I tried pump tube also, but it didn't fit well, either. It was on the small side. I put it on top of the nozzle, but the cleaning solution more or less ran into the head instead of being pumped in.
kffernandez
ddarlak, i have also tried this method, but why is it that sometimes, when some of the nozzles are clogged, cleaning solution would leak from the other "nipple" while i push through the other?
thanks!
