JASmith
Seal Image 62" Plus Base Laminator
Seal Image 62" plus laminator with the following features;
• Touch pad control with pre-programmed temperature, speed & substrate settings
• Automatic front & rear take-up shafts for release liner removal
• Swing-up in feed table makes material loading fast & easy
• 65” Heated Silicone rollers for effortless cleaning
• Simple film tension adjustment
• LED Setting indicators • Optional roll-to-roll operation
• Built-in cooling fans for smooth film surface during heat sealing
• Pull rollers that ensure consistent film tension for flat, even finish
• 6'/Minute maximum speed (1.8m/min)
• Swing out supply shafts for easy loading
• Foot switch for hands free operation Max Lam Width: 62"
• Anti-static pull roller Max Speed: 6' per minute • Ergonomic touch pad control panel
Added feature is the roll to roll option package with motorized take up
This laminator is in great working condition. There are NO CUTS on the rollers. Rollers stored in open position when not in use
Neschean Americas Website-http://www.neschenamericas.com/websites/sealbrands/sealweb.nsf/htmlalias/seal54base
Asking $9,000 (MSRP $13,700)
Buyer will be responsible for picking up or shipping the laminator
