Seal Image 62
Ditchmiester
IM having an issue where my laminator it will be running perfectly and then it just stops in the middle of the run and auto raises the roller. It's been doing this whether I'm mounting prints or putting a overlam on. Any ideas what is casing this to happen?
Bly
Ours is a different model Seal but we just had a similar problem.
Turned out when there was a load on it the safety switch light beam was moved a little, causing the machine to cut out.
Bly
We got the tech in.
It looked like he just realigned it so the beam was centred on the receptor.
