Dennis Turner
Greetings from southwest Ohio! My name is Dennis Turner, and I’m designing and fabricating a backlit sign to be installed at Colonial Pizza, a family owned restaurant in Cedarville where I've been performing weekly as a jazz guitarist for five year now. This sign is intended as a tribute to a local gent [and fellow guitarist] named Todd who was 18 when he was killed in an auto accident some years ago - his parents own Colonial Pizza. While I’m confident the sign will function as designed, I have to believe that even a modicum of advice from this group could have a tremendous impact on the end result - no amount of internet research can ever replace a trained artistic eye and years of hands-on experience. So I’d like to lay out the design choices I’ve made thus far, describe the next steps I’ve envisioned, and then ask a few specific questions. Thank you in advance for your assistance.
Image 1: This is a mock up showing where sign will be located:
Image 2: Photo of light box ready for LEDs to be installed:
The Hardware:
The sign will measure 127 x 23.5 inches and be mounted in an area bounded by existing [vintage] wooden molding. The light box has a depth of 5.5 inches and is painted white inside with the outside stained to match the existing molding. 23 segments of LED strip light [SMD5630 Pure White - 6000k] will be mounted on the rear base 5.5 inches apart on center running top to bottom - total of 12.8 meters/42 ft. overall. LED strips will be wired as three individual groups of 14ft., each with its own 5 amp power supply.
The Image:
Image 3:
The original artwork [20 ”x 3.69”] was composited in Photoshop. Guitar shown in the image is extracted from a photo I took of Todd’s main axe, a Les Paul his family still owns. On1 Resize software was used to enlarge the original image to 127 x 23.5 - no “sharpening” or other filters/tweaks were used. Image will be printed by local university print shop on HP Latex 360 Series printer on HP Backlit Paper at a cost of $.03 per square inch [total = approx. $90.00]. Two 13”x19” segments were cropped from the darkest [mid upper left quadrant] of the full scale image and will be printed as proofs - then tested in 5.5 inch deep cardboard light box. One image segment is original, and the other has been edited in Photoshop by adding white dots [from 2 to 10 pixels using photoshop gradient brush tool ] in the center of the stars to see if this will enhance the overall contrast between stars and background.
Questions:
• Are SMD5630 Pure White LED strips the best choice for this application given the content/contrast of the image? If so, is there a specific brand or source you’d recommend, or should buying from Amazon or ebay be a solid bet?
• Is printing on HP Backlit Paper with a HP Latex 360 Series printer a reasonable choice?
• Would there be a notable increase in the quality of the displayed image if I farmed this out to a vendor who specializes in printing for this type of application? If so, what kind of cost difference would it entail? [as I’m covering the cost for this project, I have to ask]. The backlit signage in Apple Stores are the finest I’ve ever seen - can you tell me who produces these for Apple?
• Do you have any other hints, tricks, caveats or comments to offer?
Bottom Line: I’m reasonably confident that my current approach will “work” and the end result will look “nice”. But with your help, I believe that “nice” could be elevated to visually stunning and jawdroppingly beautiful. So I’m ready to learn from your collective wisdom - and I look forward to returning the favor one day.
Cheers…
Dennis Turner
937 766 9000
The Hardware:
The Image:
Image 3:
Questions:
Cheers…
Dennis Turner
937 766 9000
